Ansys Learning Forum Forums Discuss Simulation Fluids Fluent Post Processing: use radial velocity component to represent flow rate? Reply To: Fluent Post Processing: use radial velocity component to represent flow rate?
wen_liu
Okay then that's the problem; once I turn them back into interior zones then they are no longer in the Flux Report panel.
And I calculated their flux (through Surface Integral) after the alignment, there is no difference before and after, which means the Fluent flux results is still opposite to the trend I saw in streamline or the raidal velocity results I got from CFD-post...
