Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Fluent Post Processing: use radial velocity component to represent flow rate? › Reply To: Fluent Post Processing: use radial velocity component to represent flow rate?
There is a note there about extra steps. The alignment will point the facets in one or other directions so if each surface has a unique name it should be OK.
