Ansys Learning Forum Forums Discuss Simulation Fluids Can a dpm particle be converted into a vof without any interaction with any wall Reply To: Can a dpm particle be converted into a vof without any interaction with any wall
Right, so a bit more complicated.
Hold up in the porous media may not be as simple as you think - read up on porosity, permeability, wetting effects etc.  So, how you define how the liquid moves may have a very significant effect on the result.
Given that, do you think DPM-VOF is the best approach? Or could Eulerian and the porous media Corey model better suit your needs?Â
