Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Load Fluent results files (cas and dat) into a single case › Reply To: Load Fluent results files (cas and dat) into a single case
Yes, because the mesh has been updated. Ensight may be a better option. Alternatively, journals in Fluent can be used; simple if you already have the image objects set up.
