Ansys Learning Forum Forums Discuss Simulation 3D Design Creation of Periodic B.C in ICEM Reply To: Creation of Periodic B.C in ICEM
Aras karimi
Dear Keyur,
The front surface of the domain is located at the origin of the coordinates, and the back surface of the domain is located in the -Z direction and at a distance of -0.2 meters from the origin of the coordinates. (In other words, the span length of the airfoil is 0.2 meters)
I went to ICEM Help and found the following:
I'm still confused and I don't know what number should I put for the offset ?
If you help me, I will thank you a thousand times.
Regards
