Ansys Learning Forum Forums Discuss Simulation Fluids Load Fluent results files (cas and dat) into a single case Reply To: Load Fluent results files (cas and dat) into a single case
I think you can only load multiple data files if the case is unchanged. As it's FSI that's not the case. What are you trying to do? Ensight may be an option, but you may be as well using journals or state files to automate image creation.
