Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › bolted joint ansys workbench › Reply To: bolted joint ansys workbench
peteroznewman
It would be best if you showed me the graph of your results, but I assume you mean that you got a single straight line with no yield point.
You would get that if you didn't add Plasticity to the material model and failed to turn on Large Deflection.
