Ansys Learning Forum › Forums › Discuss Simulation › Fluids › how to put the values for TKE and DISSIPATION RATE IN INITIALIZATION › Reply To: how to put the values for TKE and DISSIPATION RATE IN INITIALIZATION
Masooma_Qizilbash12
thank you Omkar for the reply,
I want to know that I have only one velocity of 5m/s how can I calculate the velocity deviation from local velocity to mean what this gradient means also for TDR what is this velocity gradient because in a stirred tank impeller is moving with 5000 rpm only one velocity
I shall be thankful fo the help
kind regards,
masooma
