Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › Creation of Periodic B.C in ICEM › Reply To: Creation of Periodic B.C in ICEM
Aras karimi
The distance between the two surfaces is 0.2 meters, the front surface is located at the origin of the coordinates and the back surface is located at -0.2 meters from the origin of the coordinates, in other words, the back surface is located in  -Z.
Now, there are three zeros in the offset section. Does that mean three values should be written here?
What numbers should I write?
please help me
Thank you
