Ansys Learning Forum › Forums › Kampus Merdeka Belajar › Import Engineering Data › Reply To: Import Engineering Data
October 29, 2023 at 1:58 pm
Raihan Lutfianto
Hi Syauqi. This common problem usually happens due to incorrect copy-paste process from Excel to Ansys. Have you checked that both Excel and Ansys use "commas" instead of "dots"? Also, the given Excel needs to be converted from one column to two columns. Please recheck the Excel file before copying it into Ansys.
