Ansys Learning Forum Forums Discuss Simulation General Mechanical Woven fabric modelling Reply To: Woven fabric modelling
karim.el-ghamrawy
Hi again,
Thank you for your response. I tried with linear elements without changing the mesh and it did not converge. I then removed the sizing effect and it converged! I am very curious to know why the sizing affects convergence?
The results, however, are off. I am attaching some screenshots to demonstrate that. It seems the material behaviour is captured up until a point where the material starts to behave exponentially. Any suggestions why is that happening?
Note that I am inputting the engineering strains and stresses to calibrate the material model. ANSYS outputs true stresses and strains, so I converted my experimental data to true stresses and strains for postprocessing.
Thanks again for the support.
