Ansys Learning Forum › Forums › Discuss Simulation › Electronics › problem with the solve inside in a object › Reply To: problem with the solve inside in a object
Timos
Hello, the error relates to the Material Threholds. By default, perfect Insulators have conductivity<1 Siemens/m. In this case, your material cannot be simulated with these settings. In order to solve inside, change the Insulator threshold to a value that is less than the conductivity you want to simulate. To do so:
Maxwell3D>Design Settings>Material Thresholds>Insulator value
