Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Reversed flow on 81 faces of pressure-outlet 40 › Reply To: Reversed flow on 81 faces of pressure-outlet 40
October 26, 2023 at 2:44 am
abdullahhassan
The mass flux or mass flow rate inlet/outlet of shell side is equal as only NH3 liquid is passing through it. Â
but the mass flux for tube domain is not equal. because water vapor is at inlet and water liquid is at outlet.Â
 the only issue i am facing is in tube side, as condensation happening has more reversible flow which i cant understand.
