Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Trouble Importing Pressure Load Data from CFD Wing Simulation to Individual Rib › Reply To: Trouble Importing Pressure Load Data from CFD Wing Simulation to Individual Rib
wojciech.bissinger
Now i see there is a small increase about 1 Pa of the pressure load between fluent results of the part of the wing (72.5mm) and imported pressure onto rib surface in static analysis but i dont know if it shouldn't be greater
