Ansys Learning Forum Forums Discuss Simulation 3D Design [ICEM] Airfoil Meshing in icem-cfd Reply To: [ICEM] Airfoil Meshing in icem-cfd
Aras karimi
OK, so if you say that my initial blocking is fine, so there are two strategies:
1- If I want the mesh on the surface of the wing to be uniform, then the mesh density of the front block will be different from the upper and lower blocks of the wing, which is as follows:
                                                              (Strategy 1)
2- If I want the mesh density of the front, upper and lower wing blocks to be uniform, so the mesh on the wing surface will be different, which is as follows:
        (Strategy 2)
And these two things really bother me.
Do you agree with these 2 events?
Therefore, I must accept one of these two strategies. Which one do you recommend?
