Markus
usually optiSLang automates the CAE process (you mentioned an analyses program).
If you CAE process is within Excel, you find a Tutorial for this here:
Sensitivity Analysis of a Coupled Function in Microsoft Excel (ansys.com)
optiSLang triggers the Process to be executed and gets back it results.
You rather seem to have data at hand and want to read a full set of different design in one sheet to optiSLang.
For that, I would recommend using the Text Import Wizard (ansys.com) . So, you may save your Excel sheet as a .csv file and then use the Wizard.
I hope this helps.
