Ansys Learning Forum Forums Discuss Simulation General Mechanical Initial temperature field problem in transient thermal module Reply To: Initial temperature field problem in transient thermal module
peteroznewman
Use an External Data block from the Component Systems section of the Toolbox in Workbench. Drag and drop that onto the Setup cell of your Transient Thermal analysis.  You can use that for Initial Conditions.
