Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Hyperelastic material simulation issue › Reply To: Hyperelastic material simulation issue
October 20, 2023 at 1:40 pm
Below are a few tips to try:
- Drop midside nodes. The linear shape functions can sometimes offer better stability.
- Consider a coarser mesh. Not too coarse, but slighly larger elements might be less suceptible to element distortion errors, since their integration points are not so close to the boundary.
- Switch back to Aug Lagrange and reduce the contact stiffness.
- Use many more substeps.
- If the above tips do not help, consider adding Nonlinear Adaptive Meshing.
