Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Error Ansys APDL when reading the results › Reply To: Error Ansys APDL when reading the results
October 20, 2023 at 6:45 am
Hi
I think all it says is that your .db and .rst results file are different (BC or mesh), and hence gives you the warning.
As it says use resume before restart, or when you enter POST1 to load the correct .db sub step matching the .rst file you are looking at. I hope this helps.
Also this should be of help and explain things perhaps:
https://simutechgroup.com/separating-db-database-file-from-rst-file-contents/
Erik
