Ansys Learning Forum Forums Discuss Simulation Photonics Lumopt and temperature dependence Reply To: Lumopt and temperature dependence
andy.li2
I tried starting from the best candidate (which was optimized at one temperature) but the same issue occurred - the performance at both temperatures worsened.
I'm defining the device with an LSF file and editing it for one optimization:
The optimized geometry is set using the same parameter matrix but different values for eps:
This is being optimized using 2D FDTD.
