Ansys Learning Forum Forums Discuss Simulation Fluids BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES error Reply To: BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES error
Pratik
Hi
I am simulating battery in ansys fluent but once i switch on battery model it shows some error and fluent automatically switch off. I always receive an error message saying BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES.  earlier i did some simulation but at that it didn’t shows error.
Is there any way to avoid this type of error?
Node 5: Process 14796: Received signal SIGSEGV.
Node 4: Process 18444: Received signal SIGSEGV.
Node 1: Process 14760: Received signal SIGSEGV.
Node 6: Process 9132: Received signal SIGSEGV.
Node 2: Process 2764: Received signal SIGSEGV.
Node 0: Process 11324: Received signal SIGSEGV.
=   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
=   RANK 0 PID 11324 RUNNING AT Pratik27
=   EXIT STATUS: -1 (ffffffff)
=   RANK 1 PID 14760 RUNNING AT Pratik27
=   RANK 2 PID 2764 RUNNING AT Pratik27
=   RANK 3 PID 8732 RUNNING AT Pratik27
=   RANK 6 PID 9132 RUNNING AT Pratik27
=   RANK 7 PID 15048 RUNNING AT Pratik27
=   RANK 8 PID 3508 RUNNING AT Pratik27
 The fl process could not be started.
Thank You
Pratik
