losinyao181031
Hi judy!
Thanks for your reply!
The crank angle for simulation i've set from -165 to 125. This interval is the time from the intake valve closing to the exhaust valve opening. But the calculation stopped at 5 grad. And i I tried different gas ratios, the calculation can only be completed when the proportion of hydrogen is less than 4%.When it is higher than 4%, after the calculation reaches the piston TDC, it will display: the flame in the cylinder is completely extinguished, and then the software stops calculation. Then the calculation failure is displayed in the HUD.
I want to try, even if the flame goes out, the piston will continue to run due to inertia. Is there any way to complete the calculation without considering the combustion in the cylinder?
