Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Impose a prescribed rotation around an arbitrary axis › Reply To: Impose a prescribed rotation around an arbitrary axis
Jim Day
Maybe I'm not thinking clearly yet this morning, but could you make use of *DEFORMABLE_TO_RIGID_AUTOMATIC on the skull to toggle between rigid and deformable? Or is that approach somehow not compatible with the positioning you need to do? If you're a commercial customer, you can file a case and provide a simple test case to illustrate your dilemma. Unfortunately, the forum does not allow sharing of files.
