Ansys Learning Forum Forums Discuss Simulation General Mechanical Bracket Fatigue Analysis in nCode Reply To: Bracket Fatigue Analysis in nCode
danielshaw
Maybe, but that is not its intended use.  You might be able to specify zero (or very small) cross-terms to reproduce sequential loading, but why would you try? Multi-PSD loading is intended to be used when multiple PSD loadings act simultaneously.  If the X, Y, and Z PSD loadings do not affect each other (no cross terms), I recommend using a 3 event duty cycle;  one event for each directional loading.  The multi-PSD loading approach is very rarely used.
