Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Problem with running the script at startup ICEM › Reply To: Problem with running the script at startup ICEM
October 16, 2023 at 3:51 pm
Example:
set viewer [ic_gui_set tdv_default]
ic_load_tetin box.tin
# This does iso view:
set pi 3.1415926
set pi4 [expr {$pi / 4.0}]
# ic_gui_set tdv_rot($viewer) {0 0 0 1}
ic_gui_set tdv_rotate_axis $viewer 0 1 0 $pi4
ic_gui_set tdv_rotate_axis $viewer 1 0 0 -$pi4
# requires redraw after tdv_rotate_axis where tdv_along_axis does not
ic_gui_set tdv_trans_update $viewer 1
ic_gui_set tdv_scale_to_fit $viewer {}
# Since "aie_view top" takes one 1 argument, use the call that takes 2:
#ic_gui_set tdv_along_axis $viewer -y
