Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Element orientation in ansys apdl command › Reply To: Element orientation in ansys apdl command
Govindan Nagappan
Hi Mortaza,
You can use sectype and secdata commands.
Check command reference guide for more details:
SECTYPE (ansys.com)
SECDATA (ansys.com)
Example:
sectype,3,shell
secdata,0.2,2,45                            ! thickness, material, theta
secoff,top
You can use emod to modify the esys
emod,1,esys,13
VM82 has layered elements, but this example there is no modification to ESYS - VM82 (ansys.com)
