Ansys Learning Forum Forums Discuss Simulation Fluids Befitting Course or Learning Materials: Wind Turbine Reply To: Befitting Course or Learning Materials: Wind Turbine
C N
Hello Nate,
I recommend you to use the turboworkflow in ansys fluent . I am attaching a link explaining the turbo workflow for the axial compressor which is similar to axial turbine .Please go through that. It can simplify your analysis.
(851) Using the Ansys Fluent Turbo Workflow - YouTube
Also there are courses in learning hub . Please go to ALH site ->Under fluids choose turbomachinery and then choose ansys fluent rotating machinery modelling and download it. In that there is a tutorial related to axial turbine.
At the moment for transient analysis in turboworkflow there is an example please refer this user guide link.
Chapter 12: Modeling Blade Row Interaction using Steady-State and Transient Simulations (ansys.com)
I hope this helps you in your simulation.
Thanks,
