Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Can anyone plz guide that can we hold images for different frequency points on a › Reply To: Can anyone plz guide that can we hold images for different frequency points on a
uzmayaqoob1960
No mam i am running the same file for different wavelengths.Like i set source start freq=360nm and end freq=420nm.Then i add monitors and instead of global monitor settings i use override global monior settings with two frequency points .And then i put my file on simulation.Once done i can see the results on freq1 first and then using slider  against lamda i can see the results for freq 2 as my monitors are saving results for both freq points .Now my intent is to see bth frequency results on the same image so that i can differentiate b/w them just like in hold off we can see multiple plots on single plot.I hope this will work.
