Ansys Learning Forum Forums Installation and Licensing Ansys Products Ansys Mechanical APDL GPU acceleration on A100 help Reply To: Ansys Mechanical APDL GPU acceleration on A100 help
Matt Belding
Hi Mike,
We reduced the model to the following:
28707 nodes and 24,022 elements (of which 23680 are 8-node solid elements with 3 DOF at each node, and the rest are 2-node spring-damper elements). There are also almost 86,000 DOFs and the model is analyzed for 15 sub-steps in time domain. Doing a breakdown of 16/8/4 Core with either No GPU or 1 GPU (A100). The results were the following:
NUM_CPUNUM_GPUElaspsed Time (s)CPU Time (s)
4070236.255
4166222.73
8094609.604
8156368.356
16083761.411
16163631.41
Let me know if I’m missing anything else.
Matt
