Ansys Learning Forum Forums Discuss Simulation Fluids ERROR: Latent heat cannot be less than zero! Reply To: ERROR: Latent heat cannot be less than zero!
If you're using the Evaporation/Condensation model the To and From phase matters. I always have to check the manual, but if you currently have the vapour in the To field switch that to the From field.Â
