Ansys Learning Forum Forums Discuss Simulation Fluids Relative humidity unit Reply To: Relative humidity unit
You may need a custom function. Note, RH can exceed 100% as it's a ratio and you'll not see any condensation unless you switch on the multiphase with phase change models.
