Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › I do not have the option for using micrometer as unit in spaceclaim 2021R1 › Reply To: I do not have the option for using micrometer as unit in spaceclaim 2021R1
October 7, 2023 at 12:34 pm
Mohammed OUALLAL
Hello,Â
It is a bit to late for you to have this answer, however, hopefully will b ethe case for someone else.
Indeed, if you leave the default option, you can not see micrometer unit. But, if you open the workbench and go to Units (in the tool bar), you change the units to Metrics (tonne, mm, s, °C, mA, N, mV). Then, you open SpaceClaim, or modeldesigner, and you go to SpaceClaimOption —> Units and change Length to micrometer. You could even change them to nanometers.
I hope this helps,
