Ansys Learning Forum Forums Discuss Simulation Fluids How to measure the velocity inside the rotating tube? Reply To: How to measure the velocity inside the rotating tube?
Mostly, except you are going to split the mesh using the register. That will give you a small region to monitor whatever you want on.Â
