Ansys Learning Forum › Forums › Discuss Simulation › Fluids › How to set reference temperature in multi phase flow simulation? › Reply To: How to set reference temperature in multi phase flow simulation?
October 6, 2023 at 6:50 am
afrozalam
I am simulating the plate heat exchnager with one coolant (water) is flowing over a flat plate with inlet temperature 282K and outlet temperature as 286K. and other fluid (refrigeratnt) which is evaporating on the other side of the plate with inlt temp 277.31k and outelet temperature 282.15k. the evaporation temp (dew) is given as 277.15k. May i know the saturation temperaure should be set as evapration (dew) point tmeperaure.?
Thanks
Afroz
