Ansys Learning Forum Forums Discuss Simulation General Mechanical Error when rigid body is defined Reply To: Error when rigid body is defined
Sampat Kumar
Hi Gabriel,
Please unshare the shared topology under the workbench tab in SpaceClaim and perform the shared operation only on those parts that are to be shared by using the share option under the workbench tab in SpaceClaim. You can hide the other parts of the geometry that are not to be shared while using the shared topology on the specific part. Make a separate component of the rigid and flexible parts under the geometry in the SpaceClaim. It looks like all the geometry components are under "Geom" in your case. Both components should be under "geometry."
Sampat
