Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Query regarding base material in Index perturbation model › Reply To: Query regarding base material in Index perturbation model
October 3, 2023 at 10:59 pm
Sorry the original reply was not successful.
The base material is always what the origial material is when there is no voltage/injecting power is applied to HEAT or CHARGE. In your case it seems it should be material X. Please choose the referenace point, eg no heat or charge generated and see if the result is the same as the original material.Â
