Ansys Learning Forum › Forums › Discuss Simulation › Electronics › 2D with thickness › Reply To: 2D with thickness
October 3, 2023 at 7:17 pm
Faezeh Ladani
Hi Yoon,Â
Layer 1 is on the top, based on the normal vector of that face. The direction of the Normal may depend on how the object is created. To make sure which direction is the top, you can move the face along Normal (Select the Face, from menu: Modeler>Surface>Move Faces>Along Normal...
