Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Define electrical conductivity issue › Reply To: Define electrical conductivity issue
Mingli Yan
Thanks a lot for your reply!
However, there is still a problem about how to use NE to define the conductivity. The dialogues of NE and the expression called from property dialogue are shown below. Maybe you can see that the variables available in NE are different to the expression used to define the property. Once I enter some variables in NE that are not supported by the expression in the property dialogue, the NE won’t show in the expression in the property dialogue. Is that because the units of the variables are not defined? If that is true, could you please give me some instructions on how to define the unit of these variables to make them available to define the properties?
