Ansys Learning Forum Forums Discuss Simulation LS Dyna AUTODYN Subroutine – Cycle limit Reply To: AUTODYN Subroutine – Cycle limit
audrey.piccini
Thank you for your answer, but it is not the cycle limit of the wrapup criteria that is too low because, as indicated, I always set it above 100,000. I attached the screen of the parameters I set for the simulation that crashed. Moreover, when I run the same simulation again without the subroutine in Autodyn I do not have any issues, so it is linked to the use of the subroutine.
Thank you,
Audrey
