Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Need a rotating propeller in a aerodynamics analysis, how can i do it? › Reply To: Need a rotating propeller in a aerodynamics analysis, how can i do it?
You can use sliding mesh or moving reference frame for the propeller. You then set the rotation speed and airflow speed over the aircraft.
