Ansys Learning Forum Forums Discuss Simulation Fluids Assign intensity to a particular cell in mesh Reply To: Assign intensity to a particular cell in mesh
Canh Doan
Hi, thank you for the advice. After re-mesh, I found the result is the same as the previous case. Can you help me explain why the beam is diverging when I set "theta" and "phi" is ~0 and the beam direction? This is my result and setting:
