Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Use of Impedance boundary in Eddy Current with System Coupling › Reply To: Use of Impedance boundary in Eddy Current with System Coupling
alavello
Hi. Thanks for your reply, but the issue I am reporting is not on Fluent's side but in Maxwell. My question remains unanswered, since the export of surface heat loss from Maxwell is independent from the other coupling participant, be it Fluent or Mechanical or other.
I work with with Fluent on a regular basis, and I do not foresee any trouble with the surface heat loss input from System Coupling. In fact, specifying heat rate conditions on wall boundaries is common in thermal problems.
