Ansys Learning Forum Forums Discuss Simulation General Mechanical Same results on different springs Reply To: Same results on different springs
erik.kostson
Hi
The easiest check is that for one spring design just run 2 analyses with 2 different E - modulus (G shear mod.). If that does not work, then add your results , graphs, models, bc, loads etc. here so members can see that and try and help:
All the best
Erik
