Ansys Learning Forum Forums Discuss Simulation 3D Design Sheet Metal Reply To: Sheet Metal
Roberto
Hello Devendra
I attach a photo, it would be good if it took the name like this example.
Component name + unfolded, this way you can understand if one has many unfolded open which one corresponds to.
it is also useful because usually all sheet metal workers save the unfolded (dxf/dwg) with the name of the code / component
Regards
