Ansys Learning Forum Forums Discuss Simulation 3D Design Mid-surfacing Reply To: Mid-surfacing
Charudatta Bandgar
Hello Devindra,
Are you doing a physics simulation along with it? Or is the physics simulation setup and then you are trying to get midsurface?
Perhaps that is the reason for it to not appear (although let me check on my end once, if that is the case).
Can you confirm if you are seeing other options? If you are not seeing other ribbons, it is possible that you are not getting license altogether.
Regards.
