Ansys Learning Forum Forums Discuss Simulation General Mechanical UPF linking and invoke subroutine Reply To: UPF linking and invoke subroutine
sorena shahbazi
Thank you for the explanation dear David
Those were good points, I will try to find and install the relevant versions exactly according to the approved versions, and I hope that the problem will be solved, and if the problem is solved, I will inform.
Sure, thank you for your time, if I have more questions, I will definitely ask.
with the best wishes
