Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › problem about *part_ADPTIVE_FAILURE › Reply To: problem about *part_ADPTIVE_FAILURE
September 29, 2023 at 5:42 pm
Thanks for feedback, Ram.
I tried using SMP DP version R13 and Revision: R13.1.1-17-ga451ec960f. (I check this at message file's second box)
Still same problem is happen.
as you see fig, message is end and status is still running. Is this problem is happen by memory? or really solver version of ls-dyna?
and this problem is also happen when i change failure option from *part_ADPTIVE_FAILURE to Mat 24's plastic strain failure.
If you dont mind, can you show me the ficture of end solution.
regards
