Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › 2D porous Medium non-thermal equilibrium problem › Reply To: 2D porous Medium non-thermal equilibrium problem
September 29, 2023 at 3:57 pm
Maybe. If I increase the pressure loss more for a region of higher velocity flow should I expect the flow profile to be retained?
You may also want to look at mesh resolution - not just near wall.
