Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › problem about *part_ADPTIVE_FAILURE › Reply To: problem about *part_ADPTIVE_FAILURE
Ram Gopisetti
Hi Yun,
try using SMP DP and use the solver version 13 and above, (usually the lower solver version should work with no issues as it was made Requires LS-DYNA SMP R7.1.2 (or higher) with single precision)
when we tested it, we found no issues
cheers, Ram
