Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Ansys Mechanical APDL GPU acceleration on A100 help › Reply To: Ansys Mechanical APDL GPU acceleration on A100 help
Matt Belding
It has 341,307 DOF per test case. It contains 113,769 nodes and 96,088 elements (of which 94,720 are 8-node solid elements with 3 DOF at each node, and the rest are 2-node spring-damper elements). The model is also analyzed for 3050 sub-steps in time domain. We're using 2023R1.
